Anonymous (Unregistered) 2002/07/26 15:26
Tape
Is it possible to use standard tapes (such as Spectrum) for Estex programs of sprinter?
Is it possible to record in wave format a song via audio card or tape input?
thanks
2002/07/26 15:57
The tape port (port #FE: 4 bit - OUT, 6 bit - IN ) is available in Sprinter configuration too.
Usage of tape will be possible if you have an Estex program which use this port.
No, sorry. Sprinter hasn't an Analog-Digital Converter on the Sp2000 Mainboard.
Shaos (member)
2002/07/29 13:04
It's possible through tap input as 1-bit signal (ZX-Spectrum like) with bad quality. But, I can offer simple input/output circuit for better quality of 1-bits sound. Or I can implement ISA-card of 12-bits analog input.
http://www.shaos.ru
Anonymous (Unregistered) 2002/07/29 14:01
Yeah, :-) i know 1-bit digit recording as Spectrum! How can you have better quality with only 1 bit?!?
Shaos (member)
2002/07/31 08:09
"gamma-modulation"
it's suit for speech recording
http://www.shaos.ru
Anonymous (Unregistered) 2002/07/31 10:53
Have you got it for the Spectrum?
It is only software or must have a electronic circuit?
Shaos (member)
2002/08/02 09:04
I got simple program for 1-bit recording/playing but it may be used with this circuit
You must have simple electronic circuit for it. I can paint picture of circuit and attach it here.
http://www.shaos.ru
