Thread views: 727 View all threadsNext thread*Threaded Mode
User Menu tool Reply to this post
Today, Flex Navigator (file manager) is a main program of the Sprinter computer (Anton Enin, thank you again ). But 17 programms and utilities were made for Estex during one year. So, Sprinter has more than 25 programms now. Not a lot, but usually each program has separate directory of disk. Finding an any program for executing take a time. Flex Navigator don't has user menu (like user menu of Norton Commander). May be it will be added in next version of FN, in future... GUI of Estex is a best solution, certainly. But it will be done after a new version of Disk SubSystem next year only. Today we can propose a User Menu tool which will be finished soon.
User Menu is an Estex application which serves for comfortable executing other Estex applications. It can start after the starting of the Sprinter computer and show a menu of your favorite programms. You need only to fill text file which serves for description of contents of User Menu.
Main features of User Menu tool:
Usage of any quantity of submenu.
Support of command line.
Timing of start of current program.
Return from an executed application.
Do you have another suggestions for this tool?
2002/08/21 15:37
Re: User Menu tool new [re: Alex_Goryachev]Reply to this post
Yes... what about a possibility to run more than one application (a kind of multitasking....) and graphics interface such as the "dosshell" or "viewmax"?
Re: User Menu tool new [re: flydream]Reply to this post
Multitasking (pseudo) on the Sprinter is possible but in future version of Estex only. It needs more hard work and a time. At first, for example, we need a new DSS.
But graphics interface as separated application is more really thing today.
We hope, first version of User Menu tool will be finished at the end of this week.
Today's command format:
MENU.EXE [keys] [menufile] [#section]
keys:
-h help page
-x autoexit from menu when program are terminated
menufile structure:
[MENU]
title='menu title'
item='item name', 'program' 'hot key'
autoexit='0/1'
menucolour='paper', 'ink'
barcolour='paper', 'ink'
defaultitem='number', 'time'
2002/09/04 15:12
User Menu Tool new [re: Alex_Goryachev]Reply to this post
Alex: I think it would be GOOD to know the called program's EXIT CODE in the User Menu Tool.
For example, I could want to use the menu tool to -for example- compile a MASM80 assembly program. I would like to know MASM80's exit code in order to call (or NOT call, if there were errors) SLINK.EXE.
In other words, B register contents when DSS call "EXIT" is executed should return somehow to MENU.EXE.
Can this be done?
Re: User Menu Tool new [re: Marcelo]Reply to this post
My question - just to check how I've understood your suggestion.
So, your suggestion is an EXIT CODE of executed program which User Menu should save in B register and next give it to another program?
2002/09/05 15:55
Re: User Menu Tool new [re: Alex_Goryachev]Reply to this post
Well... Not quite.
Let's assume a menu task being "Compile Assembly Project". You select a project, and then MASM80 is invoked. Suppose there's no errors. Then, SLINK.EXE is invoked (because the Menu launched a BAT file). So far, so good: You have your long-waited-for EXE file.
Now let's assume there WERE compile errors in MASM80. The launched BAT has no way to know, and blindingly launches SLINK.EXE, which will fail because there is no .RES file to link.
So, what *I THINK* we need here is some kind of DOS's IF and ERRORLEVEL implementation in such a way that upon return to the launched BAT file (from MASM80 in this case) can run or skip parts of the BAT intelligently (SLINK.EXE in this case).
Obviously, some way to SELECT FILES (with full drive, path and filename) from a "dialog" is needed as well, so MASM80 "knows" what to compile in the first place!
Just for reference, the BAT could be something like:
M80 =%D%P%F%E
:IfRetVal 0 SLINK %D%P%F.REL
In this case, ":IfRetVal" means "If EXE returned value", so the whole line would read "If Masm returned 0, then run SLink with the Drive, Path, Filename and .REL extension". Also a ":IfNotRetVal" would be desirable as well...
Long explanation, but I think it covers the point
It's clear. :) Today we have not any conditions in the bat-files. But it will come later. We have plan to implementation something like errorlevel, system environment with PATH and other system variables, %1...%9 for specify bat-parameters and etc. May be it will more smart script language. :) And I hope that it will solve some tasks.
In the first version of USERMENU have not features like this. It just a simple launcher for programs or startup menu. It can start a program or command by user choice or after some delay. Also it can start itself. You may define several menu in one file. And something else. :)
2002/09/06 00:02
Re: User Menu Tool new [re: Denis Parinov]Reply to this post
errorlevels may be write on a file!
2002/09/06 15:56
Re: User Menu Tool new [re: flydream]Reply to this post
Denis:
Thank you. I don't really think users of Sprinter need bloatware like Windoze, but I think that Estex is a little behind the position it should have as an OS. That regarding BAT files. Looking forward for the OS upgrade!
FlyDream:
I know MY progs can do anything with files. Not only that: I can launch a program from within another and check from the "parent" program the "child" exit code, in order to run or not another, different "child". But that sounds like writing a BAT interpreter myself...
The problem comes when you want to check OTHER PERSON's software exit codes. Mebbe they didn't use FILES at all to notify error codes; in the case of MASM80, it only creates the REL file(s) and nothing else. There's no way to check if it aborted due to error.
