Thread views: 106 View all threadsNext thread*Threaded Mode
Make your choice! Reply to this post
We have some things about CP/M. It can be released as a standard kernel of CP/M for Sprinter's hardware. But the other side it can be as Estex program which make CP/M environment and emulate CP/M calls. Let us know about your choice.
2002/03/16 20:40
Re: Make your choice! new [re: Denis Parinov]Reply to this post
in my opinion there aren't difference between emulated or real cp/m. As standard kernel is better because cp/m will use all resources of sprinter and I think that emulated (as external program called via estex) can have some bug (when a CP/M program want to have access to hardware)... but it is only my opinion...
2002/03/18 10:36
Re: Make your choice! new [re: Anonymous]Reply to this post
I think that only CP/M emulation is better for Sprinter.
May be CPMEMUL.EXE file, that will recall Estex routines like CP/M routines.
2002/03/21 01:24
Re: Make your choice! new [re: Shaos]Reply to this post
yes.. but you are sure that ALL programs written for CP/M can run under emulated CP/M?
2002/03/21 09:01
Re: Make your choice! new [re: flydream]Reply to this post
I think almost all, if it's CP/M 2.2 compatible.
We can do that CP/M application will think that work with real disk, that have sectors with 128 bytes size, but CP/M BIOS emulation will have image of this disk in memory. The image maked from real files from current directory.
What do you think about this idea? :)
2002/03/21 19:39
ah ok... it could be a possible solution.. :)
