Thread views: 108 View all threadsNext thread*Threaded Mode
exocet
2002/11/16 16:04
video problem again Reply to this post
Hi,
I recently got a Sprinter but I have troubles to make it work on my Philips CM8832 RGB monitor :/
It looks like the monitor cannot synchronize or the video mode is not supported, which is doubtful considering it's supposed to be regular 50Hz vertical / 15 Khz horizontal.
I use the regular scart video cable that's delivered with the Sprinter. I checked the pin connections and they seem to be correct and similar to what's shown here :
http://www.petersplus.com/download/sp_vcab.gif
I had a word with Davide Barlotti (thanks mate) who is using his Sprinter on a Philips CM8833 and it works fine for him. And It seems they're no relevant differences between the two models of monitors. So I wonder where's the problem... Undocumented differences ?
Does anyone here is using his Sprinter on a CM8832 and managed to make it work ? And just because I'm curious, on what type of monitor do you use your Sprinter ?
Cheers!
2002/11/17 12:12
Re: video problem again new [re: exocet]Reply to this post
Maybe your monitor needs "drive" instead of "sync" signals! To make drive out of sync youn to invert sync signals with a simple nand gate!
Exocet
2002/11/20 02:55
Re: video problem again new [re: cr0acker]Reply to this post
Thanks for your answer. I can try that. I suppose a nand gate is a component I can get in an electronics shop?
2002/11/20 12:19
Re: video problem again new [re: Exocet]Reply to this post
Yes! They cost less than a buck 74LS00 would be ok! It consist of 4 nand gates? your need only two!
Exocet
2002/11/21 00:07
alright...
anyway I read that Peters are working on a VGA converter... I think that would be greatly appreciated :)
