Thread views: 404 View all threadsNext thread*Threaded Mode
Pages in this thread: 1 | 2 | 3 | (show all)
2003/02/20 18:15
Re: ZX COMPATIBILITY(again) new [re: Anonymous]Reply to this post
You should format disk not with formay command in ms-dos! You should format it with Hobeta Format!
And what PC program can handle 3,5" diskettes? (a:/ drive)
AMD Copier by Paul Pavlov
2003/03/07 19:07
Re: ZX COMPATIBILITY(again) new [re: Alex_Goryachev]Reply to this post
All this things are possible to make without a PC ? Only with Sprinter is possible ?Then is possible execute all this problematics things with a Sprinter computer ?And only using the Sprinter computer ?Is possible execute programs such as pentagon demos without problems on Spinter without need a PC ?Sprinter can read and write floppy sectors, no ?on amiga exist dms, raw... dic ( whdload ) and moreand on Sprinter ? raw ? trd ? standard spectrum emulators ? ( z80? tzx tap...)Is possible make the spectrum compatibility mode such as the very good whdload ((a program for amiga for use old games and install it on hd, and programs... ) is necesary reboot the sprinter computer for change the mode ? with whdload isnt necesary, you execute the game, you exit, and... all are equal !! your windows, icons, programs... are equal...Please make Sprinter a independient computer, without need a pc for use it... could be very good add things such as... (s)vga, internet ( ethernet, internet prorams suite...), MSX compatibility... TurboR compatibility could be added with a card on Sprinter with a processor emulating a R800 or a R800 ( is possible get the r800 or a compatible if it in the market ? )Sprinter... the next generation computers... get a computer, get all !!Sprinter is a rare computer... yes... the better computer on the galaxy !!!SPRINTER RULEZ
Yes, Sprinter can work as real Spectrum if you ask about it.
Yes, certainly. We discussed a problem with launching some demos from RAM-Disks. Sprinter's RAM-Disks not support direct control of FDD controller. You should copy such demos to real TR-DOS disks.
Sectors of floppy disk? Yes.
Sprinter computer not need any Spectrum emulators. Sprinter in the Spectrum Configuration is a real Spectrum.
Sprinter has full Z80 compatible CPU (Z84C15) and a real FDD controller (VG93) chip. Other hardware are changing every time when you use Spectrum software. By two ways. You can switch Sprinter to the any possible Spectrum mode of Spectrum Configuration and use Sprinter as friendly Spectrum. Also you can launch any TRD file from Sprinter Configuration. Other formats (SCL and TAP) can be supported in the not far future.
Sprinter has Spectrum Launcher for launching spectrum software in TRD files and for creation of user's Spectrum modes.
No.
Yes, and flexibility of Sprinter's hardware allow to create powerful support for helpful software.
What else?
VGA convertor will be available next month.
Developer tools are creating so active as it is possible.
Operating system is progressing every month.
Capability of the Accelerator will be extended next version.
So, we need more programmers for business cooperation.
