Anonymous (Unregistered) 2003/04/06 21:41
TAP files' loading???
Hi.
Yarek Adamski's system (ZXVGS) and various HDD connections working with the system, can load TAP and *.z80 files without any problems (of course only TAPs with standard loader).
Will it be possible to load TAPs and *.z80 files from HDD on Sprinter? I think it's a very important question.
2003/04/07 11:44
SPECTRUM.EXE is a program which allows loading of Spectrum software images (today only from TRD files). As we have a plan of progress of Spectrum Configuration, Sprinter Update #2 will include a new version of the program which allows loading SCL and TAP files. May be, we will examine some other file formats in time.
flydream (journeyman)
2003/04/07 13:13
for now you must play tap and tzx files connecting sprinter to a pc using sound blaster and tap players
Marcelo (newbie)
2003/04/07 16:14
I must report complete success loading *.TAP thru the EAR socket in Sprinter from a Laptop with WinAMP and the Tap Player plugin (for WinAMP 2.xx).
Since *.TAPs are exclusively standard tones, I could not try non-standard ones, as there are no *.TZX plugins for WinAMP (any version). This plugin would be a great idea. Any C programmer out there could do this. I only deal with VB6, and Z80 assembly, of course!
I did not yet try to load MP3 images of cassette audio... Some say the lossy MPEG compression would not get thru... But's an idea. I read of someone that dumped WAV files to CDRom (as standard audio), and use a cheap discman to load games to the real rubbery thing. That should also work on Sprinter.
Hope it helps!
Anonymous (Unregistered) 2003/04/07 18:19
By the way, tape-connector in Sprinter, looks like joyskitck/mouse port. Is there any scheme how to make a cable for it?
PS: About TAP-files loading, we're waiting unpatiently. :) How do you think, when it's ready?
2003/04/07 19:54
yeah. You can also convert TZX to TAP using tzx2tap utility
ftp://ftp.worldofspectrum.org/pub/sinclair/tools/pc/tzx2tap.zip
Marcelo (newbie)
2003/04/08 15:16
Flydream:
The point I tried to make with TZX is that TAP files cannot cope with non-standard tones/loader routines, while TZX can. This is a personal opinion based on my almost good knowledge of TAP files and what I've read on TZX files. Please let me know if I'm wrong.
As far as I know, not always a TZX can be converted to TAP, but any TAP can be made into a TZX. That's why I ***suggested*** a C programmer make a TZX plugin (or WinAMP v3 'component') for TZX file input. I searched yesterday for them on the WinAMP site, with no success.
What CAN be done (but it is ridiculous to do) is to get a WAV from a TZX, then play it with WinAMP. That SHOULD work. But, as I said, I think the plugin/component idea rocks.
Any ZX-freak C programmer(s) willing to take the challenge?
Anonymous (Unregistered) 2003/04/08 18:23
Does Taper play a TZX? Also I think is possible using RealSpec... but... you must emulate Speccy :))
Anonymous (Unregistered) 2003/04/08 22:43
...and I still think, the best would be loading TAPs from harddisk...
PS: Does anybody know it: tape-connector in Sprinter, looks like joyskitck/mouse port. Is there any scheme how to make a cable for it? Hellp, ppl! :(
PS.2: Sprinter Crew, how do you think, when TAP-files loading can be ready?
2003/04/09 13:36
Yes, Sprinter has 25-pin connector (on bracket) for Tape/Joystick.
Please, use next info (Assembly Guide includes it too) for creation of your cable.
Signal Pin on connector
Tape OUT 8
GND / Tape 3
Tape IN 2
Joystick body 20
JK0 / RIGHT 7
JK1 / LEFT 6
JK2 / DOWN 4
JK3 / UP 5
JK4 / FIRE 22
GND 10
2003/04/09 14:17
So, when we will be ready to publish Sprinter Update #2. But before, we plan to propose several new products and new product sets in April. Checking out an advertisment on Peters Plus site.
Anonymous (Unregistered) 2003/04/09 17:56
can you anticipate something? ;-)
what kind of products are? :-)
