Utility for setting user keyboard layout and for visual diagnostics of keyboard.
Sprinter can use two keyboard layouts in same time.
You can switch keyboard (primary/secondary) by +
Usage: KEYBOARD.EXE [-switches] [layout.kbd]
Switches:
-h,? Help page
-v Keyboard visual diagnostic utility
It is a result of usage of -V key.
-s Set keyboard layout from the file
-g Get keyboard layout and write to the file
-0..7 Specify that only part of keyboard layout should be set/get
Parts:
0 - Normal w/o SHIFT layout
1 - Normal with SHIFT layout
2 - CAPS w/o SHIFT layout
3 - CAPS with SHIFT layout
4 - Normal w/o SHIFT layout (secondary)
5 - Normal with SHIFT layout (secondary)
6 - CAPS w/o SHIFT layout (secondary)
7 - CAPS with SHIFT layout (secondary)
-w Show keyboard driver setting
-b Switch on signal of full buffer
-n Switch off signal of full buffer
-c Switch on signal of change layout (primary/secondary)
-x Switch off signal of change layout
